Непрочитано 14.11.2023, 12:27
Аватар для 197
Sail Number: 197
Club: нет
Благодарностей: 25
Андреа Куки прокололся
PWA дисквалифицировали Пойнт 7 за модификацию парусов, с которыми они выиграли чемпионат, на форуме пишут, что мачткарман был на 12% шире, чем в серийных парусах.
Official Statement Regarding Johan Søe’s Disqualification
Following equipment inspection of the top riders at the PWA Slalom Finals in Japan, Danish sailor Johan Soe, DEN-37, was unfortunately found to have been using a sail that had been modified from its original factory specification and that did not meet the registered specification for the sail, including allowances for all measurement tolerances.
As such, under the rules regarding production equipment on the PWA Slalom World Tour, the protest committee had no choice but to disqualify Johan from the final event in Japan.
Whilst we sympathise with Johan to have lost the World Title under such circumstances, the rules are clear and the facts surrounding the modification of the sails, and the discrepancy between the registered specifications of the sails, and the sails Johan was using, are not in question.
The PWA takes the rules surrounding production equipment seriously and respects the efforts of the vast majority of brands and riders to adhere to the rules and compete fairly. As such, to ignore the use of equipment that had been physically modified and that did not meet the registered specification would have been unacceptable with respect to the fundamental principles of the rules.
Непрочитано 14.11.2023, 13:30
Благодарностей: 457
Держи мачткарман шире... :)
Непрочитано 14.11.2023, 13:36
Weight: 100+ (( kg.
Благодарностей: 460
Отстойно.
Johan Søe не сам модифицировал паруса, а Poin7 ему их предоставил.
С точки зрения правил все справедливо, с точки зрения духа соревнований, отстойно.
Вообще ограничения, что можно использовать только зарегистрированныую брендами матчасть, за которую те пробашляли, отстойно.
Но как грится, только бизнес, ничего личного.
Не, ну этот гнилой PWA, не поеду туда.
Лучше на Дефи, там нет таких гнилых ограничений..
Непрочитано 14.11.2023, 14:07
Аватар для 197
Sail Number: 197
Club: нет
Благодарностей: 25
Отстойно.
Думаешь, он был не в курсе?
PWA на фойлах с дронами стал очень крутым зрелищем. Реально круче даже Sail GP.
А на это бабки нужны.
Дефи смотреть не интересно, там прикольно гоняться и тусоваться.
А так-то да, если на Должанке мне будет нельзя на самодельной доске гонять, или нельзя использовать самостоятельно обрезанный парус под фойл, я расстроюсь.
Непрочитано 14.11.2023, 21:49
ВЛ@ДИМИР
Аватар для ВЛ@ДИМИР
Sail Number: RUS-575
Благодарностей: 148
Отстойно.
Андрей, а я думаю всё правильно. Если в правилах указано, что снаряга должна быть заводской, на такой и гоняйся. Ты же сам потом купишь парус на котором кто то всех чпокал в PWA, а он так не едет, будешь предъявлять претензии производителю, что он мухлюет.
Непрочитано 15.11.2023, 09:07
Gera
Club: Строгино, Дахаб
Благодарностей: 48
Интересно, а в PWA есть конструктивные ограничения . Если есть , то понятно , а если нет, то непонятен смысл этого изменеия. Может кто знает?
Непрочитано 15.11.2023, 16:34
Weight: 100+ (( kg.
Благодарностей: 460
В PWA есть строго утвержденный список досок и парусов для участия.
Какие бренды бабла закинули - тем и утвердили.
Поинт им тоже бабло платит, тем более непонятно, почему произошла такая ситуация.
Возможно, Johan выступал на новых Поинтах, за которые те не пробашляли.
Но в любом случае, старперы в PWA зачморили мальчишку, приехал, всех дернул, они ему, ша, пошел нах, не на тех парусах выступаешь. ))
А он первый был, между прочим, был бы в конце списка, никто б и не почесался.
Непрочитано 15.11.2023, 20:21
Vasilij_c
Аватар для Vasilij_c
Sail Number: 49
Club: Slalom-Piter
Благодарностей: 67
... старперы в PWA зачморили мальчишку,...
вообще интересно, кто замутил эту движуху. вангую за Severn )))
на сколько я в курсе- спортсмен, заявляясь на этап, проходит мерительную комиссию и получает печать на доски и наклейки на паруса (типа получает допуск к соревам).
что бы спортсмена дисканули в конце соревнований, нужен протест в протестовую комиссию от каких либо лиц. интересно, кто бы это был..
Непрочитано 15.11.2023, 23:37
Weight: 100+ (( kg.
Благодарностей: 460
Дык я и говорю, братья серферы небось и накляузничали... ))
Ну и кстати не впервой, вспомнил похожую ситуацию у кайтеров на Чемпионате мира в 13 году:
Елена Калинина выиграв 14 гонок из 18 на чемпионате Европы не стала чемпионкой.
https://vetru-da.ru/news/scandal_europe_camp_2013
Непрочитано 16.11.2023, 08:44
Благодарностей: 457
Страшилка на ночь: На черной черной стороне виндсерфинга, работает черный черный PR
Непрочитано 16.11.2023, 10:18
ВЛ@ДИМИР
Аватар для ВЛ@ДИМИР
Благодарностей: 148
Да у нас всё также. Есть ограничения например по ширине доски в слаломе 85 см, пока ты последний, хоть на формуле гоняй, но если взял доску 86 см и попал в призы, всё:"Давай досвидания"��
Непрочитано 16.11.2023, 12:38
Аватар для 197
Sail Number: 197
Club: нет
Благодарностей: 25
Бен Профит говорил, что всех топов проверяли и типа это обычная практика, протестов не было персональных.
В этом есть смысл, у мерителей времени мало. Остальных проверяют только после индивидуальных протестов, да еще часто за отдельные бабки от протестующего.
Непрочитано 16.11.2023, 21:55
Интересно, что дает более широкий мачткарман?
Непрочитано 17.11.2023, 08:43
Благодарностей: 95
И почему его не делают на серийных парусах?
Непрочитано 17.11.2023, 10:24
Аватар для 197
Sail Number: 197
Club: нет
Благодарностей: 25
PWA опубликовали разъяснение по результатам замеров. Там на самом деле на парусе увеличили расстояние между латами, т.е. ослабили заднюю шкаторину. Причем пишут, что явно видны следы клея, старые проколы от шва и видно несовпадение графики на парусе. Р7 и гонщик не оспаривают факт модернизации паруса. На seabreeze эпический срач по этому поводу.
Часовой пояс GMT +3, время: 08:49.
