Непрочитано 24.06.2014, 21:21
Shav
Аватар для Shav
Sail Number: RUS 712
Club: 4m/s Team
Weight: 83,5 kg.
Благодарностей: 20
Вот что по поводу контроля говорит Шон О Браен, очевидно это относиться к любому оборудованию:
Yeah, the 167w is a pretty flighty board in strong winds... Also the chicken strap recess is not helping.
Try:
1) Keep your boom up higher, around nose to forehead height as chr mentioned. Dropping the boom reduces the forward pressure on the board which makes it harder to hold the nose down as it bounces around. FYI I run my boom above my head and never drop it, regardless of wind.
2) A Kashy 70 has the area of a Z-fin/Boss/Elk 72cm actually as they have quite a wide tip area. If you can, try to get a shorter fin 66-68 as the 167w (and 167 of last year) have an extremely powerful tail, and don't require very big fins to get lift. If you can't change fins, grind a little off the front/back side of the fin head then put the fin deeper in to the box about 5mm at the back of the fin. Like, do the back bolt up SUPER tight and try to pull the back of the fin in to the board. This will rake the fin less upright about 2cm at the tip. Raking a fin back gives the fin more geometric twist which helps depower the fin downwind...
3) Put the mast track RIGHT AT THE FRONT. Literally as far as you can push the thing forwards!
4) If you're still having trouble, you could try spreading your footstraps apart. Put the front straps at the front holes and the back straps at the back holes. This widens your stance a little and can help you control the pitch of your board better with your legs. Most of us run our highwind slalom boards this way as it makes it easier to stop flying away ...
If none of this helps... Go to the gym and benchpress 5 hours; sleep; repeat...
Отсюда
Коротенько понял так:
1. Гик как можно выше на уровне лба и выше, чтобы прижимать нос доски.
2. Поменять плавник на меньший или менее мощный, но если нет возможности поменять, то сточить 5 мм с задней и верхней кромки бокса плавника и втянуть плавник задним винтом внутрь колодца. Это изменит угол наклона плавника. (голь на выдумки хитра))) ) И легче будет ехать вниз.
3. Шарнир вперёд.
4. Расставить ножные ремни как можно шире. Передний в крайнюю переднюю позицию, а задний в крайнюю заднюю позицию.
5. Если 1...4 не помогло идти в спортзал, жать штангу лежа пять часов > спать > повторить до наступления улучшений
