Neil Pryde Fusion 6.7 m
Подскажите пожалуйста может кто уже катал на данной модели , планирую купить себе , но модель вроде новая и отзывов пока никаких не слышал.
заранее спасибо
View: Film Sail Collection 2011
Introduction The brand new Fusion epitomises what windsurfing is all about by being the perfect one-sail solution for all modes of use. With this sail it doesn't matter whether you're simply freeride blasting with your mates or broadening your skill base, it can deal with anything and everything!
The entire range will rig on a 430cm mast and 160-210cm boom length - this makes the Fusion ideal for anyone looking to simplify their equipment whilst also reducing ownership costs and making it really easy to travel light!
Technical Information Each sail in the range uses five battens and no cams. The aspect ratio's are adjusted to suit the prevailing conditions, thus the larger sizes deliver more power for freeriding, whereas the smaller sails offer greater ease & manoeuvrability, essential for when the action hot's up!
A fully reinforced Dyneema X-Ply version is also available - see Fusion HD (heavy duty) - perfect for those who demand the ultimate level of durability.
Overview Fast & stable for freeriding, powerful for planing performance and getting airtime, yet light and agile enough for freestyle or wave use. Nothing will ruffle the feathers of this extremely easy to use all-rounder.
Also Consider For more freestyle or wave biased performance be sure to check out the FireFly. Those looking specifically at flat water freeriding will benefit from the extra speed and top end range offered by the HellCat.
Size Luff Boom Battens Cams Ideal Mast Option S
4.9m 422cm 165cm 5 0 430cm 400cm
5.5m 431cm 179cm 5 0 430cm 400cm
6.1m 439cm 193cm 5 0 430cm N/A
6.7m 457cm 201cm 5 0 430cm N/A
7.2m 469cm 209cm 5 0 430cm 460cm
Stock:
In Stock On Order Available Not Available
