Непрочитано 12.03.2017, 18:44
Weight: 100+ (( kg.
Продолжение...
Сегодня проехал на скутере по дистанции порядка 5 км в одну сторону, потом в другую с вышеописанными девайсами..
Схема:
Получилось так:
Туда
garmin
best 10s runs:
1: 29.237knots 54.147km/h [150.4m 10.000s]
2: 25.014knots 46.326km/h [128.7m 10.000s]
3: 14.473knots 26.804km/h [74.5m 10.000s]
4: 14.183knots 26.267km/h [73.0m 10.000s]
5: 11.516knots 21.327km/h [59.2m 10.000s]
average: 18.885knots 34.974km/h
bv5000
best 10s runs:
1: 29.028knots 53.759km/h [149.3m 10.000s]
2: 24.873knots 46.064km/h [128.0m 10.000s]
3: 14.025knots 25.974km/h [72.2m 10.000s]
4: 13.028knots 24.127km/h [67.0m 10.000s]
5: 11.793knots 21.841km/h [60.7m 10.000s]
average: 18.549knots 34.353km/h
lenovo
best 10s runs:
1: 28.992knots 53.694km/h [149.1m 10.000s]
2: 24.867knots 46.054km/h [127.9m 10.000s]
3: 13.919knots 25.778km/h [71.6m 10.000s]
4: 13.855knots 25.659km/h [71.3m 10.000s]
5: 11.771knots 21.799km/h [60.6m 10.000s]
average: 18.681knots 34.597km/h
Обратно
garmin
best 10s runs:
1: 28.691knots 53.136km/h [147.6m 10.000s]
2: 28.461knots 52.710km/h [146.4m 10.000s]
3: 28.103knots 52.047km/h [144.6m 10.000s]
4: 26.648knots 49.353km/h [137.1m 10.000s]
5: 19.000knots 35.188km/h [97.7m 10.000s]
average: 26.181knots 48.487km/h
bv5000
best 10s runs:
1: 28.673knots 53.103km/h [147.5m 10.000s]
2: 28.432knots 52.656km/h [146.3m 10.000s]
3: 28.086knots 52.015km/h [144.5m 10.000s]
4: 27.039knots 50.077km/h [139.1m 10.000s]
5: 18.954knots 35.103km/h [97.5m 10.000s]
average: 26.237knots 48.591km/h
lenovo
best 10s runs:
1: 28.359knots 52.520km/h [145.9m 10.000s]
2: 28.319knots 52.446km/h [145.7m 10.000s]
3: 27.924knots 51.715km/h [143.7m 10.000s]
4: 26.507knots 49.090km/h [136.4m 10.000s]
5: 18.510knots 34.280km/h [95.2m 10.000s]
average: 25.924knots 48.010km/h
Треки специально никак не обрабатывал, только запускал для каждого выгрузку данных для www.gps-speedsurfing.com.
Заметьте, что Гармин без доплера в треке, оба андроидных девайса с доплером.
У всех значения немного разные, но даже на короткой дистанции в 5 км и времени порядка 7-8 минут average скорость совпадает с точностью до 1 км/час.
В идеале конечно все это провести на воде, но увы, аквапака нет.
Кстати, хороший прогноз на ближайшее время, возможно покатаюсь на скорость.
Но мерять буду только Гармином, уж извините.
Непрочитано 12.03.2017, 18:59
Продолжение...
Ну, у скутера ускорения не те. Нет джайбов, уборок (не дай бог )
Купи аквапак, засунь андроид в него, и под гидрик. Недорогой аквапак работает.
У меня даже работали два пищевых пакетика ЗипЛок, вставленные один в один.
Немного поддутые воздухом, для положительности давления.
Но лучше не рисковать.
Какого типа треки у каждого аппарата?
У моего Гармина есть еще трек типа .fit. В нем кроме координат есть скорость.
Причем она не совпадает с координатной скоростью. Возможно она допплеровская.
Непрочитано 12.03.2017, 19:25
Благодарностей: 333
Для межсезонья хороший эксперимент, я прежде чем (по работе) летать на вертушке, немало обкатывал приборчики на автомобиле. И на скутере результат интересный, внушает. Но надо катать до тех пор, пока не выявятся серьезные ошибки, а они обязательно будут. Тормозить, разворачиваться, дождаться облаков и низких спутников, и придут, может не на второй раз и не на третий, но будут. Иначе мало что поймешь, кроме того, что "все хорошо".
Еще не мешало бы треки поглядеть, и на каких именно участках ошибки, с чем связаны. Обычно там угловатые треки, вертексы попадают на поворот, и каждый прибор отрабатывает это по-разному. Вплоть до ступенек и явных отскоков в сторону, я это писал выше. А в среднем притом все нормально, но чуть отскок побольше, и поймаешь.
Но возможно, проведение измерений скорости планируются только в ясную погоду с хорошими спутниками? Тогда вышеописанные трюки, может быть, и не нужны, достаточно проверок на прямых отрезках, близких к виндсерфовым галсам. Ясно и без придирок, что на сложной траектории ошибки будут, такие участки нужно просто выреать из анализа и выбрасывать, безо всякого осреднения и фильтрации. Просто на всякий случай и для чистоты анализа.
Один из трюков со скоростью, если кто не знает, подбрасывать прибор или крутить на веревочке. Но это "удар ниже пояса", разумеется ')
Как нам заметить допплера в треке, если в тексте одно значение? Вообще наличие допплеровской скорости в треке (а точнее, в треклоге) само по себе никак не влияет на сам трек, на его координаты (ну почти: иногда положение вертексов высчитываются по скорости, так пишут в доках навстар, если недостаточно спутников, но лично я не замечал такого).
Непрочитано 12.03.2017, 19:51
В GPX спецификации есть необязательное поле Speed.
В GPX треке моего гармина этого поля просто нет.
Зато в FIT треке того же аппарата (оба файла GPX и FIT присутствуют одновременно)
поле Speed наличествует.
Вычисленная координатная скорость поплясывет сильнее, среднекв отклонение отсчета от предыдущего отсчета 0.82 м/с.
Скорость из ФИТ файла гораздо ровнее - 0.16 м/с.
Координаты и время отсчетов абсолютно те же.
Мне это говорит о том, что в ФИТ файле скорость допплеровская. Или не?
Приложил график сравнения. CSPEED - координатная скорость. DSPEED - "допплеровсая" скорость.
Непрочитано 12.03.2017, 20:15
Благодарностей: 333
Это я не могу сказать априори, надо глядеть. Возможно и так.
Я имел в виду, что в представленных результатах щдопплеровской скорости не видно. Скорее всего, она и не использовалась и при расчетах, следовательно, никакого смысла нету ее упоминать. Есть ли она в файле, нету ли ее там, на итог она никак не влияет, в вышеописанных наблюдениях. Вот если бы ее извлечь и пересчитать, возможно, было бы интересно, но уж конечно не со старых чипов, которые обычно ставят в мобильники. Никто и не говорил, что сам по себе допплеровский алторитм - это вершина прогресса.
Непрочитано 12.03.2017, 20:49
Я так полагаю, что если такое значение есть, то оно, скорее всего, допплеровское.
Да. Но итересно посчитать скорость по координатам и сравнить с "этой" скоростью из трека. Они разные.
Эта техника Dead reconing, используется в крутых ГПСах. Она считает не столько по скорости, сколько по данным с датчиков ускорения. Может в туннеле координаты вычислять или в подземном паркинге.
Нам не подходит если ГПС на тушке, его болтает вместе с тушкой. Я смотрел на Г-датчики своего ГПС - каша. (трек писался когда он на шлеме закреплен был)
Или надо к лодке ГПС приделывать. Тогда можно координаты и из допплеровсих скорости/направления брать и из Г-датчиков.
Вроде программа для мобил WindRace Pro именно ее и учитывает.
А чего грузилось с Гармина, Skiminok не сказал.
Но он проще и точнее координатного.
Непрочитано 12.03.2017, 20:58
Благодарностей: 333
Все так, кроме (ненавижу цитирование):
"техника Dead reconing, используется в крутых ГПСах. Она считает не столько по скорости, сколько по данным с датчиков ускорения. "
Я не эту, современную технику имел в виду. Но спокон веку, в GPS было заложено куча всего, именно на случай плохих спутников. Сглаживание, расчет прокладкой курса, предугадывание положения и т.п. Если интересно, можно найти первые официальные описания алгоритмов навстар (система, которая легла в основу GPS), там об этом всем есть. Реально я не замечал, чтобы это широко использовалось, возможно, точность чипов росла быстрее, чем потребность в ней. Да и всякие такие ухищрения нужны были только для частного юзера. Коммерческим всегда проще было на DGPS ориентироваться... Да в общем, нам это и не важно, но просто надо представлять, что допплер - это не какая-то там побочная скорость, а самая основная, наиболее точная, которую высчитывает GPS. Скорость, рассчитанная через координаты вертексов - вторичная, менее точная. Если сейчас разница между ними невелика, за счет улучшенной точности и быстроты калькуляции - общей ситуации это не меняет.
Непрочитано 12.03.2017, 23:02
Weight: 100+ (( kg.
Вот ссылка на архив с треками, если интересно:
https://drive.google.com/file/d/0B__...ew?usp=sharing
Туда:
2 bv.gpx
2 garmin.gpx
2 lenovo.gpx
Обратно:
3 bv.gpx
3 garmin.gpx
3 lenovo.gpx
С Гармина трек скачивался в родную программу Training Center и оттуда экспортировался, как .gpx
C Андроида WindRace позволяет тоже экспортировать .gpx
Треки грузились в www.gps-speed.com и оттуда экспорт в www.gps-speedsurfing.com, оттуда пять best 10s runs и average.
В Гармине каждая точка в треке выглядит примерно так:
<trkpt lat="28.4793899" lon="34.4918841">
<ele>63.4000000</ele>
<time>2017-03-12T14:19:56Z</time>
</trkpt>
В Андроиде так:
<trkpt lat="28.5034333" lon="34.5172933">
<time>2017-03-12T14:38:49.000Z</time>
<course>67.66</course>
<speed>.0</speed>
<geoidheight>1.2</geoidheight>
<name>#1173 0:19:32.2</name>
<fix>3d</fix>
<sat>9</sat>
<hdop>.86</hdop>
<vdop>.89</vdop>
<pdop>1.24</pdop>
</trkpt>
Непрочитано 12.03.2017, 23:20
Если ты откроешь Гармин как ЮСБ флешку, то есть ли у тебя там .FIT файлы?
В моем гармине они лежат в поддиректории Garmin/Activity/
Если найдешь, то можешь ли тоже поделиться?
Непрочитано 12.03.2017, 23:30
Weight: 100+ (( kg.
Не, с моим Гармином общение только по воздуху через брелок ANT и его драйвер.
Доступа к файловой системе нет или я не знаю как.
Экспорт в .gpx или какой-то .tcx
Непрочитано 12.03.2017, 23:53
попробуй послать .tcx.
Вот твой трек 2bv с коорд и допп скоростями
такое ощущение, что андроид гладит допплеровские скорости и они отстают на 1 сек.
Хотя, это моя прога делает отставание, считая коорд скорость по текущей и следующей точке.
В случае с моим гармином так и надо. Иначе коорд скорость отстает.
А в случае с андроидом наверное наборот. Хм...
Непрочитано 13.03.2017, 00:02
Благодарностей: 333
Speed это, скорее всего, допплеровская скорость. Я не помню критериев по hdop, vdop, но 9 спутников это вполне достаточно. В идеале, hdop учитывает высоту спутников и возможную ошибку, и по нему надо фильтровать, но в наше многоспутниковое время, да на широте египта, это обычно в норме. Хотя я бы глянул базу на несколько сотен треков разных сезонов-лет, чтобы в этом убедиться. Например, три-четыре спутника несколько раз в месяц - было бы некомильфо, как и критичные hdop.
Непрочитано 13.03.2017, 00:44
угу. ДОП<1 это идеально
https://ru.wikipedia.org/wiki/DOP
спутники должны быть не просто высоко/низко, но и в разных частях неба. Чем они дальше друг от друга, тем "толше треугольники" и точнее рассчеты.
При 9 спутниках явно можно было найти "громкие" спутники в хороших местах.
Поэтому наверное треки такие гладкие. Координаты мало поплясывают.
А вот на моем треке - пила.
Непрочитано 13.03.2017, 01:26
Благодарностей: 333
Дык, было бы всегда с десяток спутников, а то ведь мы не в египте, плюс влажность-облачность. Серьезные приборы в нмеа пишут еще и уровень связи с каждым спутником. Она видна на экране, но в треклог не идет в гарминах, даже в паре с ноутом. А неплохо бы иметь и эти данные для полной гарантии.
Непрочитано 13.03.2017, 09:32
Weight: 100+ (( kg.
Продолжение...
Итак, все таки, практический вопрос, волнующий пользующегося GPS серфера, с какой же максимальной скоростью я ехал?
Приведу еще несколько цифр из анализа вышеприведенных треков:
(оставил только км/час, чтоб не распылять внимание)
max - макс. скорость.
2s - макс. средняя на 2-х секундах скорость.
10s - макс. средняя на 10 секундах скорость.
трек - максимальное и два соседних значений скорости, округленных до целых км/час
Туда
garmin
max: 57.868
2s: 56.540
10s: 54.147
трек: 52 58 55
bv5000
max: 54.821
2s: 54.782
10s: 53.759
трек: 55 55 54
lenovo
max: 54.65814
2s: 54.630
10s: 53.694
трек: 55 55 55
Обратно
garmin
max: 56.270
2s: 55.966
10s: 53.136
трек: 55 56 56
bv5000
max: 55.958
2s: 55.720
10s: 53.103
трек: 55 56 55
lenovo
max: 55.186
2s: 55.183
10s: 52.520
трек: 55 55 54
Ну чтож, из приведенных цифр видно, что бездоплерному Гармину верить на слово насчет максималки нельзя.
В первом треке есть сильная разница в скорости между точками: 52 58 55
2-х секундная макс. скорость ее несколько нивелирует, но все одно значение сильно отличается от других девайсов.
При этом доплерные андроиды себе таких выкрутасов не позволяют, треки ровные.
Соответственно, максимальной или 2-секундной скорости от Гармина можно доверять, только удалив вручную точки со скоростями, сильно отличающимися от соседних.
При этом 10-секундные скорости всех девайсов вполне укладываются в погрешность 1 км/час.
Как резюме:
Использовании любого "будильника" для получения максимальной скорости на виндсерфинге возможно, но пользовать максимальную скорость на треке нужно аккуратно, не пропуская точек с большой разницей относительно окружающих, либо пользоваться фильтрами, отсекающими такие точки автоматом.
А вообще, более-менее объективной максималкой является средняя максимальная 10s скорость, где все неравномерности трека сглаживаются.
Конец.
Часовой пояс GMT +3, время: 10:52.
